I’m working more and more with animated labels in Keyshot, and I love it.
However if I am reusing an animated label in a new project, I get asked where do I want to export the png frames. If I already have an image sequence, is it possible to import the frames rather than repeating the creation of the frames?
The question is how you transfer material with labels into a new project?
I actually didn’t realise you could select all the frames and it would import those.
I didn’t want to copy the material, just a video label. I have also found that sometimes when re-opening a file, the video label with all the frames was there, but the video would not play, it would only show the first frame and so I have been needing to re add it as a ;label.
I didn’t want to recreate the frames from mp4 multiple times, but hadn’t realised that those frames can all be selected an imported.
